PSG-1
- Joined
- Jul 17, 2011
- 50
Because they are NOT superior, they are INFERIOR.
I've got a Triton aluminum trailer for my Yamaha VX110 jet ski. Had it about 3 years. Last week, my girlfriend took the ski to the river, and on the way back, she said she heard metal falling off going down the road.
So, I took a look at it, and I saw that the leaf springs were already disintegrating. WTH? We've only had this thing 3 years, and we rinse it off every time it's used in salt water.
I ordered a new set of springs, and they got here yesterday. So, I went ahead and blocked up the trailer, and pulled the axle from under it.
I started looking at the axle, which, BTW, they simply paint, no galvanized coating or anything like that. I noticed that where it was rusted, it looked rather thin.
So, I decided I would salvage the spindle stubs, get a piece of galvanized pipe, and make a new axle.
I began cutting through the axle, and I immediately saw that it was paper thin, so, I made the right call about replacing it.
However, as I was cutting near the ends, looking for the spindle stub, I couldn't find one.
Once I lopped off the ends, I noticed that the spindles indeed did not have stubs that fit into the axle like all the spindles I have installed over the past 15 years as a welder dealing with trailers.
Instead, they simply butted their spindle to the end of the axle and welded it. That is NOT the way it's supposed to be done! The spindle should always have a stub, about 3-4 inches long, that extends into the axle tube. You drill a hole, and you plug weld the spindle stub, as well as welding around its perimeter. This way, it is much more secure.
Even worse was the fact that they drilled a hole all the way through their spindle, for grease to go into the axle tube.
In theory, on the blackboard, and in a college-boy engineer's mind, this might be a good idea.
But under actual use, it's a POS idea! Why? Because, the grease is by-passing the bearings, and just running into the axle. The bearings are NOT being properly lubed, which would explain why they were rather noisy when I spun the wheels of the axle. So, it looks as though I will have to replace my bearings, as well.
I think a crackhead could have designed something better than this colossal piece of junk they call an axle. Like I said, I've been doing this for over 15 years, and this is by far one of the shoddiest axles I have EVER seen!
So, if you're in the market to buy a trailer, check to see who made the axle. If it has a tag on it that says "Superior", avoid it like the plague. Or you will find out the hard way when the weld around the perimeter of the spindle breaks, and the wheel falls off.
