Hi guys,<br /><br />first off I wanna say how cool this bb is. I've been all over this place soaking (pun intended) all the info you've put out. I have a question though, I have an older Avon 12' inflatable with wood floor boards. The boards are getting very ratty so to speak. I want to make/replace the three main boards. My question is what wood do I use? Can I use Pine and the Epoxy coat the puppies? Or do I have to use a hardwood like oak and then coat the puppies with epoxy like CPES? What would you recommend. BTW I plan on always disassembling the boat after every days use so its the boat won't be in the water 90% of the time. OF course the boards will probably be wet 99% of the time while I'm in the water (going in the ocean).
Thanks in advance for any info/suggestions.<br /><br />Adam
