Avon restoration
ReelRaider
Is there anyway to restore the rubber on an Avon? I have tried the Seapower cleaner without the results I was hoping for. Anyone have a better solution?<br /><br />Thanks - Al
Gav
Re: Avon restoration
I myself have built many Avon ribs and the only cure is a new tube. With simple instruction anyone should do this task themselves. E-mail for details.<br />Alternativley when Inext visit the states i'll do it for you.............If you buy the beers!<br /><br />G
Wan Zai
I hv an Avon Workboat 4.0 meter soft bottom. I had it since 1997. How long would it last before I have to change to a new tube [boat] in tropical condition.
Gav
Sudden impulse.<br />It really depends on weight,use and the color of the tube. On a 4mtr you probably have 900grm hpln. A lighter cloth but in keeping with its length. Use could be lesiure or being soft bottomed probably not commercial.Thirdly the color, basically the darker the better. I know this goes against logic as in white reflects light but believe me U.V. will perish a white tube in tropical conditions if not cared for in 5-8 tears. Yet a grey tube in a like for like enviroment and again not cared for would expect to last 9-16 years. Obviousley if both boats were cared for you could double these figures but the golden rule is if you want value for your money go for grey.
Wan Zai
Thanks for the info. I hv a grey color Avon inflatable. I currently put it on top of the pontoon at a marina because of barnacle problem if I leave it on the water.<br /><br />I spray and wipe with Armor All to maintain the tube as protection from UV. My pressure gage is faulty and I just estimate the hardness of the tube by slapping the tube. It does not work very well today when the boat actually folded into 2 while I was speeding through a wave. Thank god, it unfolded back after the engine cut off but I got a lot of bruise slipping through the anti slip deck.
zorro1
Sudden.<br /> You made me laugh about the folding situation although it must have been scary!<br />Anything you apply to the tube will benefit it appart from the re-coating tins of yuk that are supposed to make the tube look like new. If its a preventative lotin then good. Anything that claims new youthfull looks (sound familiar!)avoid like the plague!!!!!!!<br />Happy boating my friend.<br />Gav.
