Ayuh,.. Tail Pipes for Tailgunner...
Hi TG,... Not really Tailpipes, but it sounds Good,...:p
I mentioned to you about the extended risers to help with reversion when Hod-Roddin' a Boat,...
Well,....
Last night during the "Tool" photo shoot,...
I popped off a few on several differently configured Risers,.....
From left to right,...
There's a stock Merc. riser,.. a cast aluminum Eddie Marine riser,.. a SSteel Eddie Marine riser,+ a Gil Marine riser...
The distance from vertical exhaust flow to the point of water introduction is 5, 1/2" on the stock Merc riser...
The Eddie cast riser is an Inch longer,...
The Eddie SSteel riser is up to 10",...
And,... The Gil's are at 16"....
I hope this clears up the point I was makin',.....;)
WizeOne
Re: Ayuh,.. Tail Pipes for Tailgunner...
Looks like they would fit my Ford motor mani's!:p
Tail_Gunner
Well,....
No. 4 is thourgh the y-pipe i assume....I am playing around with the number 3 right now...
Actually i am trying to get comfortable with injector pulses every 200 rpm and finding way's to shorten the process..not even going to timing curves.
I do know however i am going to work with silicone hose....Probably a dry exhasut spilling the water on the outdrive or some crazy arse ideal...I guess i would jump off the diving board like right now if i could find a way to dump the noise into the y=pipe..:confused:
Your point was well taken.;)
