Mischief Managed
- Joined
- Dec 6, 2005
- 1,928
My Bravo 3 serial number is OL470685 and it's a 2:0. Something failed in it today and the pinion gear is completely destroyed. I can't even pull the U-joint assembly out of the driveshaft housing because the pinion teeth are all peened over which enlarged the diameter of the gear. I pulled large amounts of what looked like steel wool out of the thing and I have no idea how bad the damage really is, but I'm certain it's more than just the pinion gear...
Any tips on how to get the U-joint assembly out? I can't even think about rebuilding the thing if I can't take it apart.
The gear housing (lower unit) seems OK. I was thinking about bolting it to a used Bravo 1 driveshaft housing (upper unit). I found a complete used Bravo 1 with a serial number that also starts with OL and has a 1.5 ratio, for a good price. I think the driveshaft housing (upper unit) would be a direct replacement for mine. Am I correct? I figure I could just sell the Bravo 1 gear case (lower unit) to help offset the cost of my repair.
