Re: B30 Fuel injection conversion
Thanks guys, just the info i was looking for.
Wellcraft, thanks for the links, very helpfull.
I called about 30 junkyards today looking for volvo 164, no luck, then called the one nearest to my house again and lucky me they put out a 164E out today.
I went there, checked out the motor, was fully intact. Got all the pushrods, pushrod guides, and the BOSCH d-jet ECU; all for $40,
Hopefully i'll sell the ecu and make some $$
Since i got the pushrods, i doubt i will change anything, yet
, but still an interesting idea.
Reading more about it, the main challenge(as seen on the surface) would be adjusting all the sensors to my application, the hardest (i think) would be the pressure sensor, one on the block and one in intake manifold(if i understood correctly). Then i would have to replace the distributor( not too hard since the replacement would be direct fit, same breaker points style, just added electronics which send timing info to ECU), cylinder temp sensor would have to be changed, fuel pump with extra relays, and new fuse box for all the electronics.
Everything else is on/in the manifold. If i understand correctly, the major part of this injection is the pressure in the manifold, this determines the length of time the jet is on and that is the only factor that changes, spray concentration does not change.
About the duty cycle, what parts would be most affected by it? I know the injectors would most likely not last. The intake manifold would last, i think.
I think the head is very very similar, besides some temp sensor.
ROGGERS, are you certain the valves are different?? Anyway to find out for sure? Also from what i read the compression is lower on same injected motors, how would this affect my situation.
If the valve train is identical and compression change is irrelevant, would you guys agree the injected head would work in marine application?
Might be a silly question: would the duty cycle of marine motor compare to an auto motor running in first gear all the time, probably uphill?
So as of now i think this would be a hell of head ache, especially all the sensors. Having said that, i think this has the potential to work.
