B75 honda
LEE MICHNAL
Hello,
Im a little new here, I have a B75 Honda outboard and need a carburator for it, would anyone know where I could find one??
Dave
Alumarine
A bit more info might help.
Is it a 7.5 hp or 75 hp?
Approximate age?
Model number and/or serial number?
LEE MICHNAL
When i purchased the motor i found out someone has been working on the carb and there is a couple of
Parts missing and i cant locate a used carb do you have any ideas??
Thanks for your response.
ondarvr
That's a good reason. We still don't know what motor it so though, so helping will be tough. Your best bet will be eBay and possibly a whole parts motor, but if it's an older Honda there aren't that many parts around.
ahicks
B75 would be the 7.5 if I'm not mistaken. The 75hp would be a BF75.
For our OP, if you can't locate a replacement carb, I think your options are pretty limited, no? You'll need to dig in to the parts books and figure out the part numbers for your missing parts so you can order them. If this seems beyond you, there are outfits that specialize in rebuilding carbs. Sending your carb to them will cost a lot more than just the parts, but when you get it back it would have a warranty.....
WillieBill
ahicks...I too have an older Honda 7.5hp., but mine won't idle. I've done what I can but without success. I believe I have a plugged line in the float bowl, but without removing the brass plug at a 90 degree turn it's impossible to gain visual access and removing any debris if there is some.
Above, you mention "outfits that specialize in rebuilding carbs". I may decide to go that route. Can you please pass on a name or two who do that work?
Thanks a bunch! WB
