stourm
- Joined
- Feb 21, 2009
- 48
I am sure you guys will remember me from my avatar but just as a recap, I bought a fairly nice boat with a very corroded motor and cracking around the prop. I have been talking to a guy that listed some parts, including a decent looking lower unit, out on Ebay. He's about 4 hours drive from here and he had offered to sell the lower to me for $150. I am not entirely certain it will fit, but its the best shot I have and it looks as if it will so I am going to drive down there and get it on Saturday. He told me on the phone yesterday that he would give me everything he had from his old engine (listed in the pictures below) for $150 since he really didn't need it. He said the power head was bad but everything else had been working fine when he parted it out. There may actually be more than what the pictures show, I don't know. That's just all he had pictures of on the ebay page. Do you guys think it is a good buy for this stuff?
Also, I took the boat out onto the water last week and here is what happened. The motor starts and runs fine, but when I put it in gear and gave it throttle it took a lot of throttle to really get up to sounding normal...like it didn't have much power. I throttled it all the way down and at full throttle it sounded good, but really didn't move the boat very quickly. It seemed like it went slower than my father-in-laws 40 horse and this is a 140. I have already ordered a compression tester and it should be here either this week or beginning of next but here are the questions. I had tilted as far down as it would go. Is it possible that at that tilt, it was at the wrong angle? The front of the boat was reeeeeally up in the air when I was driving full throttle so I wondered if maybe I should have worked the tilt a little more. It's electric tilt/trim. Also, could the throttle cable linkage need adjusting? If you have poor compression or blown cylinders, would it really hinder the power or would it do something else? Remember, I am just learning so any help would be appreciated.
By the way, it was like 34 degrees outside, windy, and the water was a bit choppy so I didn't spend just a whole lot of time out there with it. I basically wanted to see if it would run before I spent anymore money and time, and it did crank and run just not as well as it should have. I had dumped a can of seafoam into the gas/oil mix also before heading out there. About half the gas in it is new gas and half of it old gas from when the old man had it last year. He had also dumped some kind of penzoil gas treatment into it also that I didn't know about before I put in the seafoam (called him up and asked him just before we left out, but didn't think it would hurt because it has probably 14 or so gallons in it so it was decently diluted I think.)
I kept doing something stupid first time out. Trying to crank it with the engine still tilted up out of the water. *sigh* I'll get the hang of it yet. Oh, and one more thing. My tach apparently doesn't work and I have been trying to figure that out also. Sure would help to see what RPMs I am getting... I also wondered if the power problem might have been caused by some cavitation from the exhaust leaking around that poor, cracked prop. I did was Ezeke said and eased the throttle forward so it didn't run away.
![5d30_1[1].jpg 5d30_1[1].jpg](https://forums.iboats.com/data/attachments/22/22029-e48fe5ac276684d1c4a32a58995ca985.jpg)
![5a80_1[1].jpg 5a80_1[1].jpg](https://forums.iboats.com/data/attachments/22/22027-6bfb26c53a8acafc085ed69a603b3586.jpg)
![63f5_1[1].jpg 63f5_1[1].jpg](https://forums.iboats.com/data/attachments/22/22023-ede8aadf801b19eda4b4216d8692ba7d.jpg)
![6180_1[1].jpg 6180_1[1].jpg](https://forums.iboats.com/data/attachments/22/22025-c780aca9acec5ffa317a67916a4d5fdf.jpg)
