BACK AT IT! spring 70hp start up
RaScLeS
So last season i got all of a few good hours out of this motor....the stator,trigger,plugs,impeller everything was replaced the carbs cleaned all by a professional.
anyways after it needed the stator it never worked 100% but WOT power was restored and it took off. as soon as i let off slightly it would flop on its face.
NOW:
It started up rough, smoking alot (some is storage spray) but after a few mins it continues to smoke like a chimney.
it pee's water so thats good for this year,
I took the lower plug wire off, no start, and the upper plug wire off, no start (so hopefully thats running on all 3 fine)
I notice some fuel on all plugs, they all smell like fuel. (it looked like the lower piston was not working last fall the plug was dry) but now is wet.
Is this motor in need of a carb adjustment ? or timing is out or .....?
please help, i know for a fact this motor will react just like last fall (only take off on full throttle)
I need it smooth all the way like it should. the gas is one day old and is premium gasoline with shell oil mixed 50:1
ANY HELP that anyone can provide will be considered id be extreemly happy if the motor works like it did for those few hours. (I will post pics of one last wire that looks some what decayed) but im sure its still ok
RaScLeS
Re: BACK AT IT! spring 70hp start up
keep this on top TTT I will jump for joy if this all works mint soon
