sebas54
- Joined
- Jun 17, 2007
- 334
Hi, I have a 1987 gm 4.3l merc. I/O. Two barrel carb. that I just rebuilt.
Today I took the boat for a test drive and it ran good except at high rpms it would backfire or make a noise and the rpm gauge would tick up or down 1 rpm.
Could the adjustment screw cause this on the carb? I just sort of screwed it in.
Also when going over wave or wakes it sounded like it was losing power. this only happened sometime as well with the backfire noise.
This only happenes when the boat was under load; in neutral it runs fine.
I have recently replaced the fuel pump, fuel filter, water separator and other things. I tested it for blockage in the fuel system and there was non. i also tested for a vacum leak and there was non.
Thanks.
Thanks.
