TAC_Double
- Joined
- Sep 23, 2006
- 93
Hello all....
Just got back from the lake after installing the 1975 85hp on the pontoon. Noticed a few things that were a little off and I am hoping you all have the answers.
All in all the engine ran well, very pleased with it on the pontoon.
I noticed that the boat does not plain out like it did before. Do I need to adjust the till lock pin to a differnet set of holes?
WOT RPM was at 3800. The prop that is on it is a 4 blade and I don't know the specs. I do have a 3 blade that I am going to try on it. I am correct in thinking that WOT should be between 5000 - 5500?
I also noticed that I could hear a chatter/grind when shifting from neutral to forward or reverse... seems worse going to forward. So I am pretty sure i moved some adjustment when I put in the water pump. Is there an easy fix?
Also notice the boat pulls to the right a bit... do i need to move the trim tab a bit to the right?
Thanks for any help or advise you can offer!
