backfire OMC engine--- after work done
alternative
I had my boat towed in by a marina after it wouldnt start and then hydrolocked... * first i cleared the water from cylinders and tried starting it .. no go.. so they towed in and pulled out of water. Checking over the boat they didnt tell me any reason for the hydolock.. they didnt see the water so they said it was OK... they did get it started and test drove it and now they say it is backfiring??? i didnt have a problem with that before.. and need to know why they wont check for water entering the cylinders.. why is it backfiring and could the water(hydrolock ) just have been from one heavy wave day at the dock or during the launch 3 days earlier? and what about bad gas .. could that be my starting and backfire problem.. or something more serious like a head gasket???? i m so confused!
tommays
Re: backfire OMC engine--- after work done
read this its all about water<br /><br /> http://www.boatfix.com/merc/Bullet/01/01_13.pdf <br /><br />it could be a one shot deal with the water there is not enough info here to say like 1 cyl or 8 <br /><br />backfire could be a lot of things you need to give move info about the maintence the boat has recieved so it can be narrowed down<br /><br />tommays
DHPMARINE
Did the motor not start because it was hydralocked,or did it hydralock while you were trying to start it?This also will help track the problem.My guess is the motor is a 3.0Liter,and hydralocked while trying to start.Am I right?<br /><br />just a guess,DHP
Don S
DHP<br />He has a 305 OMC, and several posts that are basically on the same subject, that you might want to read for further information.<br /> One of the posts <br /> Another one <br /> And another
DHPMARINE
Thanks Don S.<br />Beached boat,4ft waves......next topic<br />DHP
