hello folks. I bought a 1970 chieftain with 2.5 mercruser. At first would only run if I put gas directly in carb. Took Rochester 2 barrel apart cleaned and blew out everything with air. Re installed. Float bowl empty inlet plugged. It started right up and ran smoothly. Put in water to try it out. Haven’t had in water yet. Started right up runs smoothly eased it up to 2500 rpms no problem. Then 3000. Then 4000. That was wot. Twice while increasing rpms especially if I went up fast it would backfire maybe couple times then run smoothly. What would make it backfire as how to fix it. I ran off a clean new 6 gal gas tank with filter in line. Also is that the right rpm for wot on this 120 hp. 21’ Aluminium chieftain. GPS speed at wot was 30 mph At 3000 was 26 mph
