backfire
roxylass
i have a 1989 british seagull not pumping water to good so i took the head off to clean the water passages got them all nice and clean everything back together first pull on the rope a back fire next ten pulls nothing getting a bright blue spark and the spark plug is wet before i stripped the head she would start 1st 2nd pull :confused:
keith-uk
Re: backfire
More info would help.
Did you replace the head gasket?
what compression has it got?
JB
Re: backfire
Check the timing. Sounds like the mag is way out of synch.
