I just replaced the engine in my 1995 Cobalt. Its a 5.0L Volvo Gl, with a Ford 302 block.
Not sure if any of that info is necessary, just following the adults only instructions.
When I rev the engine in neutral, it sounds great, but when its in gear it starts backfiring through the carb when I get above 1200 RPMs. I plan to have the carb rebuilt, because what can that hurt? The boat has been sitting since '09 when the block was cracked, so I assume it needs to be rebuilt anyway. I checked the timing with a gun yesterday and got it set right. All of the spark plugs and wires are firing. The engine actually runs smoother at a higher rpm, so I assume the problem is in the carb. I thought it was getting too much gas, but adjusting that didn't make it much better. Anybody have any ideas that differ from what I am thinking?
Thanks
Thanks
