fsjcowboy
- Joined
- Jul 22, 2009
- 41
My question involves a 1987 Four Winns Horizon 180 with a 4.3L OMC. This motor will not fire... A rebuilt carb feeds plenty of fuel to the engine. Even when using starting fluid, I can get no firing. My big question is:Can a faulty Motorola alternator cause a no-spark or a weak spark condition? The starter system operates normally. I have verified spark at the coil wire and plug wires with a test light. Dwell is a bit low right now at 31 degrees. New points, plugs, rotor, and condenser. I have removed and grounded the plugs to the engine to visually see the spark at the plug ends. I HAVE NOT replaced any plug wires or dist. cap.
