Bad compression in one of my cylinders. Any hope?
chistedude
Hey everybody,
Alright, 2001 3.0 mercruiser. Been trying to get it to start up for past month and a half or so after I realized my engine had filled up with rain water. I rebuilt the carb, new fuel pump, dis cap and rotor, oil changed, all of which it needed, still won't run. I did a compression check and got bad news. Results were:
Cyl 1: 170
Cyl 2:135
Cyl 3: 85
Cyl 4: 150
So obviously now i realize it won't start due to bad compression, specifically no. 3. I've tried to doctor it up w some oil on top of the cyl, no good, and just yesterday i treated it with about half a can of fogging oil, tried to start it again today, still won't start. I plan on continuing that until the can is gone, trying to go by the theory of motion and lotion to get it going. But I'm starting to lose hope.
Anyone have any ideas? If it comes down to having to replace the piston rings, I'm not too sure if it'll be worth it.
Thanks!
Re: Bad compression in one of my cylinders. Any hope?
Hey everybody,
Cyl 1: 170
Cyl 2:135
Cyl 3: 85
Cyl 4: 150
Thanks!
Ayuh,... Welcome Aboard,... With that much oil added, I'd sooner think ya got a Valve problem,...
Addin' oil would help seal the rings, atleast temporarily raisin' the compression,...
If that Ain't happenin', ya look to Bad Valves....
Yank the Head, 'n drag it on over to yer local Machine Shop... They'll tell ya how Bad it's gonna hurt,... ;)
Hoosmatroos
Yup, oil doesn't help to stuck valves.
chistedude
So yall think it could be A valve? How would the rain water affect it so? I'm up for any ideas so I'll definately be looking into it? Is there anyway to test this theory before removing the whole head? And also, let's say this one cylinder is completely screwed, by means of rings and or valves, would the engine at least be trying to start? Because it acts like none of them are even trying to fire, keeping in mind new plugs gapped correctly and rotor and cap and proper fuel delivery...
chistedude
And can anyone point me in the direction of a good walk through on how to pull the head.
Thanks!
Fishermark
Pulling the head is easy, but before you do that, have you checked to see if you have spark?
chistedude
Also, any input on timing possibly making this issue? I haven't done anything to change it but I mean if there's no stark at the right moment, no fire right?
chistedude
Ya I've checked for spark with a neon spark tester, spark at every cylinder.
chistedude
So I'm getting fire now, but it won't stay running as soon as I stop turning the key. Any suggestions?
Speakrdude
Ensign
Change the ignition switch, or simply hot wire it to test. Have had many switches go bad and only energize the circuit while in the start position.
