I have a 99 Sea Ray 19'
Some times the control panel is on even though no one touched it. Causing battery drain between uses. Its oval shaped with the horn button in the middle and all others around it. I took it out and used low pressure air to blow it out and it was ok for a day. Now its not working right again.
I can't find one online. Can someone point me in the right direction? Thanks. The name on the back is Grayhill with several #. One is 93yy5061-1 9826 and 00235.
