I have a '68 6hp that quits after a few seconds unless i keep pumping the primer bulb, it runs fine if i keep pumping the bulb. Is it a bad fuel pump, or bad primer bulb? If i have to rebuild the fuel pump do i need to get the kit with check valves or do i just need the regular kit?
