EBBTIDE 78
- Joined
- Nov 25, 2005
- 39
Would a bad gas-cap gasket cause a low pressure condition on the suction side. I have a 77' - 70hp Evinrude. The motor will start up, warm up, & run great 90% of the time. After getting to a prticular fishing spot on LaSalle Lake in LaSalle Il. & catching 60 or so Yellow Bass we decided to move on. The motor would start up and idle fine for a min. or so, but when trying to accelerate the engine would bog and die. Trying the second time same result. Went to check the bulb and it was not completly hard. Pumped it up firm and motor started and ran just fine. I did check today for leaks and there were none. All connections and gas lines have no leaks. But I did notice the bulb again was semi-hard. I was told this could be a "lean condition". The floats need to be checked. And that I should have the carbs. checked, to cure this problem.
