bad gas or stuck valve?
nick9118
went out on the boat right after just felling up. not long after running started running rough and no power thought i might just have bad gas. now drined out the gas and put new. no better the motor is acting like its missing anf the carb is popping and when i get on the acc. the carb is blowing out fuel. not alot but eough any help would be nice thanks
84Monaco
Re: bad gas or stuck valve?
Have you checked the condition of your water/fuel separator? I had a similar problem recently and there are a lot of things that can cause symptoms like this.
i don't have a water/fuel separator
Nope,... But there Are fuel filters in the fuel pump,+ Carb....
Maclin
If you really suspect a stuck valve then do a compression check.
