Can you guys tell me what would cause a brand new Impeller to go bad? I had the mechanic install it, and have not run the engine but a few times since he did this. He had run it quite a bit, and I fired it up, and its no longer pumping any water.
I am a stickler for never starting the engine without the hose hooked up, and have not done this. I have only started it maybe 4 times since he put the new impeller in. I am just wondering what might have caused this. As I have never run into a bad impeller in all my 11 years of boating as I have replaced them before they are to bad.
There is no water coming out of the hose from the impller that goes to the thermostat housing, as he had me pull this off and start it with water running to the outdrive. It is a 94 Alpha 1 Drive v8 5.0 litre.
Thanks,
Bryan
Thanks,
Bryan
