bad oil leak 7.4 mercrusier
rick36
Morning,
I have a 1988 7.4 Mercruiser 454 Wellcraft 28' that's blowing oil badly. It never lost oil pressure or got hot I just tuned it up and installed new ignition parts and it ran great it loses about a quart and hour had over a quart in bilge.It made the cabin stink that's: how i found it.:facepalm:
It seems to be in the front of the motor its leaking on belts and flying all over. It only leaks when underway. I suspect the raw water pump or timing cover i cant really find it because the motor is all black in color. Any help would be awesome thanks in advance!:cool:
midcarolina
Re: bad oil leak 7.4 mercrusier
A quart an hour is a pretty good size oil leak......could be timing cover could be intake valley gasket or oil pan/front seal,
If you have a smart phone with a flash stick it down there and take pics, or use a digital camera..........have you checked to see if the crank case is building excessive pressure?
rick36
I did not check crank case pressure not sure how to. I have a compression tester.If i were to guess its leaking onto the belts i could see where it was spraying my holding tank from the alt belt.
midcarolina
the attachment not working......host your pics with photobucket or drop box ......there are tons of free hosting sites.
