Bad pack or something else
dsinger
V4 77 OMC
Had no spark on 4 when I switched it at the pack it fired. Is this the pack or is there something else I need to check before I purchase a new one.
rickdb1boat
Re: Bad pack or something else
.Can you give a little more detail...I guess this goes back to the clean plug post??
dsinger
I found the number four plug was not sparking. I first thought it was the coil pack but when I hooked that coil pack up to the number 2 spot on the power pack it sparked. I then hooked the number two coil pack up to the number four spot on the pack it would not fire. Any coil i hooked up to the number four spot on my pack they would not spark.
