Sirrobin53
- Joined
- Mar 13, 2012
- 189
I have a rough idle and pop/backfire on the pipe. I have been reading a lot of forums and they have led me to believe that the regulator /rectifier is the culprit. Burned yellow leads on the regulator and at the bayonet connection that goes under the flywheel, along with no charging and eratic tachometer. I would like to know what voltage the 2 yellow wires from the stator are supposed to be. I assume that the regulator is bad by no output. I have 18v between the 2 leads from the stator. Thanks in advance.
