Hi did a compression test on my 1969 55 horse outboard and found I had none on #1 cyl. #2 120psi, #3 120 psi, pulled the head off and found that #1 piston was shot rings bent slight scoring on wall top of piston looks like someone through hydrochloric acid in the cyl. it was a bad sight. but there was good news after this #2 and #3 pistons looked normal. Now how hard would it be to change the number 1 piston what am I looking at in replacing it. what is involved with this task.any help is welcome. thanks bob
