Madtown_Joe
- Joined
- May 29, 2011
- 13
So here is my problem,
I bought a 91 Rinker with a 4.3 Mercruiser last year and in the fall had the boat winterized at a local marina. They changed all the fluids and all that good stuff. The boat started right up no problems.
Now, I took it back for the summer run up and when I went to pick it up they told me it was hard to start. I got it home and wanted to see what they meant by hard to start. What happens when I turn the key the engine turns over maybe for a second then stops and then starts to turn over and then stops again. This will repeat as long as I turn the key. I went through and cleaned all of the connections from the battery, starter, ground, and also the circuit breaker and I what I think is a relay next to it. Tried to turn it over again and same thing. Also I replaced the battery last year and when I got it home charged it up again. I think the battery is fine. I also metered out the voltage to the starter and also the the circuit breaker and that is fine. I also metered out the grounds and they are also fine.
My guess is that the starter has gone bad. Is it possible to go bad after sitting all winter? Is there anything else that I should check before replacing it.
Thanks to anyone that is able to point me in the right direction!
