I have a 02 Starcraft 190 that I bought used. When I was out the other day I filled my livewell and it seemed to work ok as I filled it with no problem. I noticed when I got ready to go in that the light on the rocker switch was lite up in the off position. The pump will run in the rec. mode but will not run in the fill mode, where as when I started out that day they both worked both ways. Also when it is in the off position with the light still on, after about three min. or so the circiut breaker will pop. I haven't taken the panel off yet to check the wiring as there is one screw that will be a hard one to get at but will start this A.M. I am thinking it's probaly a bad switch but any other ideas would help if possible. Thanks
