Matchrocket
- Joined
- Sep 17, 2002
- 9
I have already searched the forums for my issue and I didn't find it. I suspect that my tack is reading wrong. I checked to make sure it was set correctly and I believe it is. I have a 95 Merc 115 HP 4-cyl 2-Stroke outboard and the setting should be at 6P, correct? The max cursing RPM for this boat should be ~5300 RPM. Yet when I am running at 5000 I am only going about 25MPH @just over 1/2 throttle. The motor doesn't sound like it is even turning that fast. I have a 13 X 19 prop on it. Out of the water the tachometer says I am idling @ just under 2K RPM. But it really doesn't sound that way. I have only hit WOT once and I was just over 6K. I didn't like that much so I backed out. I am not the first owner of this boat. Any help would be greatly appreciated.
