2001 35HP Johnson (J35VL3SIE)
Well, I was cruising along wide open when there was a decent bang, and the engine died. I got it started again, but it sounded terrible, like rod knock.
I putted back to shore, and with it running, I pulled each plug wire off one at a time, and the top one had no effect on engine speed or sound. I pulled the head off back home, and there is carnage.
The top pison broke apart at the ring land, and pieces of ring and piston are embedded into the top of the piston, and marked up the head somewhat. I knew I was in for a cylinder bore, then oversize pistons at that point. Head looks salvageable. The bad cylinder is scored, but that should be fixed with an overbore.
Now my conundrum. I discovered the pistons are already oversized 0.030. Maybe my google-foo isn't so good, but I cannot find a 0.040 piston for this outboard. Am I totally hosed here? Is it possible to re-sleeve these?
Thanks for any assistance.
