george3405
- Joined
- Jan 29, 2007
- 54
I've posted before and I'm still having problems. My engine had run in January. It sat 2 weeks and would not run. I changed the coil & power pack (both bad), the 2 spark plugs, the gas/oil completely, the spark plug wires, and added a water seperator. The best I can get is a backfire and smoke out the exhaust when I crank it over. It is only a 2 cylinder and the plug wires are installed correctly as well as the wires to the coil. The #1 piston is in the correct position with the timing marks on the flywheel. When I installed the power pack the terminals on the wires would only fit back the way they were removed, except the 2 wires that sit under the power pack when it is installed. These 2 wires look like they are color coded the same so I figured they connect to either wire. Could this be my problem. I've tried reversing the 2 plug wires to see if that cured the problem and it didn't. The flywheel key is not sheared either and the nut is torqued correctly. The fuel system appears to functioning correctly. I believe it's an ignition problem. Any ideas? Thanks for all your help!
George3405
George3405
