hey folks.
I imagine i am doing something stupid but I have never had a bait well before. I have a 1952, and when I turn on the bait well the pump starts to fill the well but because of the drain on the bottom I never get more than two inches of water in it. How am I suppose to get the entire well to fill if I was to put in bait? From what I can tell there are two drains. One high for an overflow and another that is down low near the bottom of the tank. I am guessing that the lower drain is only to be used if you want to drain the well entirely after use but I could be wrong. Is it souppose to twist or something to close that lower drain? I tried to twist it but did not want to break anything.
Thanks
Gazelle
Thanks
Gazelle
