baja outlaw prop
24outlaw
I have a baja 24 outlaw, what is the fastest prop i can run? 454 chevy, bravo 1 outdrive
Robbabob
Re: baja outlaw prop
Welcome aboard iBoats!
Before we can help, we need some essential data:
Items 1-4 are essential for meaningful response to most questions.
1) Performance issue you are trying to correct.
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
3) Current prop diameter and pitch (required).
4) Wide open throttle RPM and speed with an average load (very helpful)
5) Engine/drive make, model, year, and HP
6) Boat make model, year, length and weight
Get back to us and you will find a nice set of options provide by the many experts!
:cool:
Ayuh,... The 1 with the best blade design for your hull, with the tallest pitch that allows the motor to turn 4800rpms at Wot...
642mx
One of the fastest props you can put on a Baja is a Mercury Mirage Plus. As far as pitch goes, we'll need to know what prop your running, your wide open rpms, and which 454 (mag?).
24outlaw
:cool:
1. More Top End Speed
2. Mercury Quicksilver, Mirage, Stainless
3. Diameter - 14ish / Pitch - 21
4. 4700rpm / 55 MPH (3 wide bodies and 2 chicks)
5. Mercuriser 7.4L 310 HP Bravo 1 outdrive 1998
6. 1998 24' Baja Outlaw approx 4500 dry weight
642mx
Is that a standard Mirage or a Mirage Plus? The Plus (newer version) has a little more cup and is a little faster.
Your MPH and RPM look good for a 21p.... that might be all the faster its going to be with the 7.4L.
