hello all-
I'm new to the forum, and also purchased my "first" boat recently. anyhow, to the puropse of the post! The boat is an 89 baja sunsport 196. It has a 5.7 with a yamaha outdrive. The the boat weighs 2300 lbs, so with a 350 i presume it'll run pretty well once i get the right prop. The current prop is an aluminum, and i believe is says " 21- w" .. but the prop has a layer of paint making it difficult to read. am i correct in assuming the 21 is the pitch? I want to go stainless, and apparently quiksilver makes an adapter so i can run a turbo prop, or possibly a mercury. I know the yamaha outdrives are fairly obsolete, so i think i'll go that route. And furthermore... does anyone have experience with a similar setup that can point in the right direction as far as prop selection and speeds? thank you for your time
