CalicoKid
- Joined
- May 27, 2002
- 1,599
Below are some Photo's of my Sunsport 164. It is a 1988 and is in like-new original condition. I bought it from the second owner in the summer of 2002. She's powered by a 1988 Johnson 110.<br /><br />
<br /><br />
<br /><br />I had to remove the seats in order to scrub the carpeting and clean out every little corner and crevase. The interior came out looking new.<br /> <br />
<br /><br />
<br /><br />Last winter I again removed the seats and completely rewired the boat. It all started with the need for a water pressure gauge. I decided to replace all of the gauges and rewire the boat since the original wiring, typical of small boats, was a mess and sure to cause me trouble. I had to push in the cig. lighter to beep the horn! In order to fit six gauges where there used to be five I needed to fill the original holes, glass everything over from behind, and redrill new holes for the new layout. On the front of the dash I had to add a composite panel to cover the evidence and improve the look of the cockpit. The panel is carbon fiber with a top layer of aluminized glass mat. The gauges are from Beede.<br /><br />
<br /><br />
<br /><br />
<br /><br />I added a high current fuse panel near the battery to allow for the possibility of a future stereo system or other options. There is also a ground buss. From here a no. 8 wire feeds the fuse panel at the helm which also features a ground buss. There should be no reason for cobbled taps in this boat! In the pictures there are only two branches wired from the helm, the nav. lights and the bilge pump. I've completed wiring of the horn circuit, power outlets etc. since the pics were taken.<br /><br />
<br /><br />The Stunner, on a beautiful Fall day.<br />If I keep her this Spring I'd like to play with setbacks and see if I can run over 55 mph consistently.
