dingbat
- Joined
- Nov 20, 2001
- 16,329
keyboard buffer issues can pop up from a unresponsive data request.It doesn't affect typing speed.
My laptop does it when my network connection with work times out.
i would be more interested in his latency valuesOut of curiosity, what is your internet speed? Do a test here:
http://www.speedtest.net/
Tell us what your download speed is.
Hard to believe a keyboard buffer would be an issue since the buffer is around 35 characters.keyboard buffer issues can pop up from a unresponsive data request.
i assume you using a somewhat modern computer with adequate memory and hard drive space? Did you get a connection lost message?Hard to believe a keyboard buffer would be an issue since the buffer is around 35 characters.
As a test, I turned off my WiFi in the middle of this edit. Not a problem typing at all, at least in this web page. I hit the edit button....typed my entire response...then turned wifi back on. No problem.
Add to the fact that most people never defragment their hard drives, I don't doubt it.I just got rid of a 2002 vintage Dell XPS that would start that $rap when the hard drive was getting full. Too much data to handle w/o writes. CPU usage spike. Dog mode would set in.
No connection lost message. No more modern than what OP is using.
Judging from the processor he has, his computer is around 4 years old.
Wow. Latency @ 234 ms is absolutely brutal. Download isn't bad, upload is quite good. I've never heard of latency that slow except for people usng satellite which a lot of times is even slower than that. If you're not using a satellite connection I'm not sure what to tell you except that your computer is NOT causing the slow latency.latency @ 234 ms, Download @ 25.29 mbps, Upload @ 3.54 mbps
I have had other tests with other services that showed lower.
My HD is 282 gb with 222 gb available. I did just run defrrag.
