imported_stump jumper
- Joined
- Jul 19, 2006
- 71
I am in the final stages of putting my boat back together. I am rigging the new console and I have run into another problem. I bought a used tilt/trim unit and installed. The unit worked fine if I hooked it up to the battery. Last night I tied it back in to the remote wires, both at the shifter and under the cover. The tilt motor barely runs, will not lift the motor. I have spark to my engine, it starts and runs. I am a liitle stuck as to what my next culprit may be. All was working fine with the old unit, it just developed a leak in the casing. Should I suspect relays, even though they were working? Thanks in advance for the help?
