While surfing the local Craigslist today. I came across a 1999 Mercury 15hp longshaft Manual start 2stroke...rebuilt carb and new water pump...$400, with 6 gal tank.
I figured since I'm looking for a motor for my PROJECT Alumacraft, why not take a look. Got over to the sellers place, it was sitting on the mud floor of his shed. He mounted it on a barrel, hooked up the fuel line, pumped it up,on the 2nd pull it was purring like a kitten, ran it FNR all was good,water was spewing out the PEE hole like a fire hydrant, had normal wear and tear scratches, and it was dirty. Checked oil in gear case, all was good(no Milk) I offered him $300 and he took it. Now here is the issue..It was mounted on a sailboat, with the motor leg in the water for a long time, must have had a lot of Barnacles built up on lower leg and prop, as someone spent a lot of time scraping them off. The question is...how in the heck do I get the rest of the CRUD off..is there something I can spray on the lower leg and prop to clean them off......looking for ideas...Thanks
