Hi,<br /><br />I have a 75 model Electric start 40Hp johnson that came with a boat I bought - the boat was a bargain so I wasn't too concerned about how good the motor was. The motor starts but sounds like it's running on only one cylinder. Realising I had a bit of work to do I am doing some initial work to estimate just how bad the motor is.<br /><br />I don't yet have a compression tester but on pulling the plugs and just pushing a finger into each hole in turn, the lower piston pushes hard but the upper doesn't seem to push quite as hard and also wants to suck air back in on the way back down ... is this normal ????<br /><br />I have only cranked once each time so not sure how much of a 'test' this really is....<br /><br />Any comments on whether this is normal or a useless test? (beyond going out and buying a compression tester which I intend to do)<br /><br />Thanks.
