Seeking clarification (and education).
1978 AQ120B. Seloc Manual says:
Ignition Timing Basic..... 10 BTDC
Ignition Timing Strobe..... 36-38 degrees @ 2800
Original Operators Manual says:
The same for Basic, but
Strobe setting says - 61.6 - 80.0 r/s (3700-4800 rm)....36-38 degrees BTDC
I set the timing with my strobe light, engine at idle, to 10 degrees BTDC. I think I did it incorrectly.
Do I need to set the rpm between 3700-4800 and then set the timing to 36-38 degrees BTDC?
What is "Basic Timing"?
What is the "2800" in the Seloc manual? If it's RPMs, why is it so different than the Operators Manual spec of 3700-4800?
Thanks
Thanks
