Hi All! I have a few basic fuel system questions about a 1998 Mercruiser 4.3 LH I/O.
Is it true that the electric fuel pump does not work until there is oil pressure? In other words, the electric fuel pump doesn't run until after the engine has started.
When you pump the lever before starting the engine, where does the accelerator pump get its gas from? The bowl in the carburetor?
After a long layup, how does the bowl fill up?
Under normal conditions, how many weeks would gas remain in the bowl?
Thanks.
Thanks.
