Re: Basic Outboard Wiring
As mentioned before, start by measuring battery voltage as you key the mic. That represents a high current draw. If that draw drops the system voltage below the threshold for the ECM in the engine it can't run properly. the way to prove or disprove this, is to wire the radio temporarily to another battery If it still kills the engine its RF engergy radiating into the electrics that's the problem.
The service manual for your engine will contain the schematics. But you will find the ECU is just a big blob in the diagram and it will be meaningless from a troubleshooting standpoint.
