Getting_started
- Joined
- Nov 14, 2008
- 21
I'm installing this switch on my boat. After some initial confusion, I think I've figured it out but wanted to run it by folks who actually know what they're doing. Looks like I need to wire in a grounding bar from the battery where all of the circuits connected to this switch get their ground. From the ground bar, run a wire over to the neg. on the switch. All the red wires on the switch panel should go to the pos. on the devices being switched: small bilge pump, running lights, plotter. Correct ?
The other issue is that the fuses look to be a type of circuit breaker but I can't seem to get them to reset. Each switch has a back light and they all work if I put power to them. Problem is that if I run through the fuses, it's a no go. Can't really take them out to look inside. Any ideas or suggestions ??
Thanks
