oops!
- Joined
- Oct 18, 2007
- 12,932
a forum member on a thread here, said "he ground down some stringers and allmost coughed up a lung.....!
i thought it important everyone know the risks and see the minimum equipment for grinding and glassing.
first of all......grinding...
fiberglass dust consists of very small particles.....
once inside the human lung...they never ever break down...if in small enough amounts the human lung can "pass them out" via coughing and very small hairs in your lungs and throat. that literally pass stuff out of the lung and into the throat.......kinda like people pass back a human at a rock concert by supporting the humans body on a whole lot of hands....
in order to stop the inhalation of fiberglass dust, a proper resporator system must be worn....
one that totally seals off any air from getting by the mask. uasually a rubber nose/mouth cup with two changable filters
thoes little paper dust masks will not do the job...at all
a good seal around your face is crutial
im sorry for being blunt....but if you cant afford one of these type of masks...you cant afford to do the work.......the doctors bills in a few years will kill you if the glass dust doesnt...
these masks arent cheap...good ones are around 60 dollars.....
you might get lucky and get one at a garage sale!
these masks must be worn when doing ALL glass work......grinding...mixing or applying resin...making peanut butter...or cleaning with acetone
the fumes of resin or acetone are toxic and will harm you.....or just plain ol knock you out.....
even if your working out doors......wear your mask....
goggles are worn at the same time.....obviously when grinding or drilling....
but also wear goggled when mixing resin...! it can splash....... i got a few drops on my goggles tonight as i was mixing......so allways wear your goggles...
work safe...then you can enjoy your work
cheers
oops
cheers
oops
