Re: Bass boat bow control panel.
Hey Silvertip, thanks for getting back. I did forget to mention the run charge switch. I kind of gave up on that one a while back knowing that I would have to run my 6 amp output system from the motor for a long, long time in order to charge even a single lead cell battery if in fact this switches purpose was to do that. Doubtful I figured because this boat was designed to have 3 batteries. I could tell by the three trays in the bilge compartment and being familiar with the parallel batteries for the bow system and the single for the cranking battery. Just one really big problem. You hit the nail on the head when you said "the next owner will thank you for not scewing around with this system". Unfortunatly, I happen to be this said next owner with a no thank you neccesary to whoever in fact did just exactly that! The bow panel has been completely butchered. I have discovered that the battery in the front in what I am assuming is an anchor or just storage box and is wired directly and independantly to a plug that has been installed into the cool, once functioning bow panel with a single 12 v system twist lock style plug. Reading what you have to say about the 12/24 plug-in socket that does still exist on the panel and the way it is suppose to work, I now beleive there is a strong possibility that where this 12 volt socket is, the 12/24 selector switch once existed. The rest of the system is completely useless and literally cut out of the system. Well, exept for the tilt trim switch that thank the Saints they have left connected. I am tryng to return the boat back into good all around functioning condition. I can not change the mods that have been done to the boat casting deck and the missing passenger side consol, but this boat in my opinion is in pretty darn good shape for being just over 30 years old. Fact is, I love it. I do not look forward to the lakes all freezing this soon coming winter(exept for the ice fishing is great). Thanks again for you reply and and any more info on this that you could throw my way would really be appreciated!!!
