beavertrapper70
- Joined
- May 2, 2008
- 14
Does anyone know who makes bass trackers pontoon bunk trailers? I found a 25 foot 2005 dual axle with brakes. I am curious as to who makes it and the quality of the trailers
I have a 1997 Tracker Trailstar Trailer for my 25' barge. It (knock on wood) is holding up well, but I know it was stored inside for the better part of it's life. It doesn't appear most of the trailers are made with the best of materials...lots of painted iron and steel.
IMHO, I would be worried about how well the trailer is been treated under "commercial use" vs. a private owner. Inspect carefully, especially axles, bearings, brakes, etc. $1,090 seems high to me, but may depend on what part of the country you are in. Around here, you can get a new trailer for less than the $2K range.
Interesting you want to move away from the "lift" type trailer. Mine is the cradle type, and I would prefer the lift type. Main reason is with the cradle type, I can't put the toon off the trailer nor can I inspect the bottom of the toons. Guess there are pros and cons to both styles.
Where are you from newcomlr? I cant find a new trailer with brakes around here for less that 2500. I am from Ohio, and I travel to Michigan a lot.
The big question is do you really need them?
Yes.
The last example includes 10" disc Brakes.
To be clear, I'm not advocating one brand over the other ...just wanted to show that for $1000 plus whatever for repairs you end up with a repaired 8 year old trailer...for not a ton more you can get a new trailer.
Sometimes, my best tool is my checkbook.
I completely agree that sometimes it's better to pony up. As Andy told Aunt Bee, "Aunt Bee, pay the man.". But, unless I'm looking at the wrong description (I'm looking at the last one) that trailer does not include brakes. The description you posted clearly states the ten inch disc brakes are an option.
Options Include: Spare Tire and Bracket, Side Bunk Guides (Set of 4), 10" Disc Brakes w/ 14" Tires, Swing-Away Tongue (30" off overall length), LED Tail Light System. (my italics)
