Basshunter 10 foot - Gas or Electric?
marlboro180
Hey guys, wondering about setting up a 10 foot Basshunter -
My bud owes me a few bucks, and in consideration of money, I am getting a neat little boat. Looks like a tiny pontoon boat, two person setup. Rated for 5 hp max, per the plate on the back.
My intended use is just trolling around on the river I live on. It flows pretty steady in the spring, but for most of the year, which is when I intend on using it, it has a 2-3 mph flow at the surface for the most part, although in the narrows there is faster water.
I have an older 5 hp Eska that runs ok, but is a little hard to start somedays, and it is generally on the jonboat anyway. The one thing I do not like about it is that the Eska does not have reverse, the motor swings around 180 degrees to get reverse. So , is this a good motor to put on the Basshunter ?
Or should I consider an electric trolling motor ? They have reverse, right? I like the idea of being able to troll around nearly silently, and not have to mess with fuel, etc. I know NOTHING about trolling motors other than they have varying amounts of thrust and one uses a deep cell battery to power them.
As a side note, the river here can get really shallow depending on time of year, rainfall, or lack of rainfall , so something that can tip up would be crucial.
What would you do? Anybody have a picture on theirs ? I do not have a picture of mine, only one that is similar
mpsyamaha
Re: Basshunter 10 foot - Gas or Electric?
i used to have a little basshunter like that, had it for at least 10 years....
i found that a 36lb trolling motor was plenty (although i didnt fish in much moving water). with just me in the boat it would really cruise with the trolling motor. it worked much better in the front for me, a lot more control for fishing. in the fast currents you are talking about you may want a bigger badder trolling motor though.
i put a 3.5hp kicker on the back for a bit, pushed the boat faster than a trolling motor but still not fast. it was definitely very squirrelly at wot or close to it. since youre not planing it just kinda plows along. the only advantage of a gas motor is for covering longer distances really.
marlboro180
Thanks for the input. Thinking about it more , I am leaning toward the electric trolling motor. Bigger is Better?
Fed up
i looked into one of these at one time...i think they are pretty cool...
i have a 14ft flat bottom jon boat that is all electric...twin motors, one front and one on the rear.. 35lb minnkota on the front and a on the rear there is a bass pro shop prowler 55 lb thrust... the boat was set up for small lake and pond fishing..
i can tell you that it will move my jon boat at a pretty good clip...
i have never had it in much current but have had it in some pretty good wind, and it still moved faster than i can paddle...lol..
Silvertip
Don't know how far you intend to run "up river" but with an electric you will need more than one battery if your excursions have any distance. 2-3 MPH current is pretty swift and trollers top out at about that speed on a "V" hull. Make your choice carefully and yes -- bigger is better but it also requires more battery power. Trollers are called that for a reason -- they are trollers. They are not intended as a primary power source.
marlboro180
Funny, I just got back from a paddle trip upriver and ran into a guy with a flatback canoe with a 50# trolling motor, single battery. He claims to be able to run a few hours, and be able to take it upstream to the next dam, which is exactly my goal as well. It is about a 2.5 mile upstream trip.
I am not concerned about the speed , just the journey. If/ when the battery dies, I can just float/ paddle back home:)
