Re: batterie dont charge???
Will they take a charge with an auto charger? If not - bad battery. Water level in battery? Connections clean & tight? Put a volt meter on tha battery & read. Start motor & check the voltage. If higher the system is charging. If not you will need to troubleshoot your charging circuit which is best done with a shop manual.
