Alan_Scott
- Joined
- Nov 25, 2011
- 69
I just acquired a '87 Celebrity 210V (OMC 350) and since there is little chance of finding any manuals for it, plus I know nothing about power boats...
The battery in the #1 position is a regular automotive battery while the #2 position is a deep cycle, is this the OEM setup or did someone cut corners with #1? Since both are shot, I'm leaning towards replacing them with dual use batteries, is this a mistake?
Here is the switch I have:
I am assuming position #1 is used for engine operations while #2 is used for accessories when the engine is off and then "1 + 2" to charge both at the same time via the engine alternator?
Mounted above #1 battery is a 10A battery charger that must run from the 125v 30A "Shore Power" circuit and on the off chance I'd have the chance to use it, would I recharge the batteries separately or use the "1 + 2" position and charge both at the same time?
Thanks and I hope these are not completely stupid questions
