Re: Battery Amps
Just because your battery is capable of supplying 1000 cranking amps, it doesn't mean it HAS to. The actual cranking amperage is determined by the motor, your motor will only draw as much as it needs. If your motor tries to draw more than the battery can supply, it will cause problems, but you'll never have problems if your motor is trying to draw less than your battery can supply. <br /><br />As long as your battery is fully charged, you are OK. The only times you'll have problems is if your battery is over-charged, which is almost impossible, or if your battery is under-charged, which I am sure you are familiar with.
